Had some fuel starvation issues last year that seem to have been caused by a blocked pickup tube. I hired this job out to a mechanic with very unsatisfactory results. I'm redoing the fuel system and am now working towards cleaning out my tank. Currently have it pumped "dry" and all the hoses removed for replacement. Looking through the fuel level sender hole I can see a pretty good layer of scum on the bottom of the tank, with trails from where my pump hose scraped it up.
I was hoping maybe I could remove the tank to give it a thorough cleaning, but everything I've read here says it's not going to fit out the companionway. I'm not ready to cut up the tank to get it out. It's not leaking.
I have a Seabuilt 8" inspection port on order. Any tips on installing that would be very welcome. I haven't been able to determine where the tank baffles are yet. There's no indication I can see on the outside of the tank. My attempts at sounding were fruitless (I can never hear wall studs either). I assume the tank must be baffled.
Any tips and tricks for cleaning would also be welcome.
Just go at it with a rag on a stick? Or with a solvent? A mechanic at the yard suggested "purple engine cleaner".
Thanks as always to all the amazing minds of this forum!
