Thanks @Prairie Schooner !Really nicely done Dave. I like how you highlighted the parts you were talking about. Did you do that on a separate image and do a fade transition? Very effective.
Your results raise a question for me. Can an engine run TOO cool? Does it need a certain temperature to run efficiently?
Thanks @Kenneth K !Nice video Dave.
It looks like you have the out-dated alternator bracket on that engine. Have you read of the potential problems associated with that setup?
From MaineSail's website: https://www.pbase.com/mainecruising/universal_alternator_bracketIf you can point me to any information on my alternator bracket, that would great!
I was able to get rid of the belt dust very easily--surprised me how easily. Just put some washers behind the bracket bolts here and there and aligned it by eye--a metal ruler helped my eye. Magically stopped all the dust. I had imagined having to bend the bracket and lots of trouble--no such difficulty.Thanks @Kenneth K !
I have not read about the potential problem with my setup and would definitely like to find out more. I do get quite a bit of belt dust, so I think I may have some alignment problems, which I'll check out further this spring. If you can point me to any information on my alternator bracket, that would great!
Thanks!
Dave
I would recommend buying a new thermostat (unfortunately, and also recommend getting the exact one for the engine rather than a generic one from the autoparts store as the 25XP seems to have a slightly odd diameter-it is a 160 degree and opens at that temp) and keeping it around until you have occasion to take things apart again--I see no problem that needs immediate attention. I, too, have trouble with the same engine getting the temp up in the slip without a good load. The manual says this engine is meant to run at 160 but, as you note, I would not be concerned if it showed 180--many--maybe most--recreational diesels run at 180 and I think that slightly higher temp is probably marginally better for the engine in the long run. I also would not put much stock in 10 degree differences in the readings as the gauges are notoriously not really accurate. it is also common when you empty and refill the antifreeze to get air pockets in the system that take time to work out; so folks should not be too concerned if the coolant needs to be topped off right after the first fill--probably not leaking, but needs to be checked and topped off. Also, the only reliable way to check coolant levels in any engine is to remove the radiator cap--there are too many variables in the overflow tank to trust the levels in them. My overflow tank on my 32-200 is mounted in the lazerette and is so high relative to the engine that it is useless because anything it it would just run out if you open the radiator cap--not sure what they were thinking. FWIW.Thanks @Prairie Schooner !
Yes, they are separate images and I did a fade transition. I'm glad you like that.
When I couldn't get the temperature to rise after replacing the heat exchanger, I did worry about the engine running too cool, and found articles saying it can lead to sludge buildup in the engine and increased fuel consumption (see https://industrial-radiator.com/diesel-engine-equipment-in-cold-operating-temperatures/#:~:text=Overcooling can cause sludge formation,valve lifters and valve stems. and https://eeuroparts.com/blog/engine-running-cold-waiting-can-damaging/). Our marina docks are reaching end of life, and the finger of the slip I rented in 2021 was on its last legs, so I hesitated to put the engine in gear and raise the RPMs. Running the engine in neutral at higher RPMs was not really sufficient to raise the temperature, at least in the time I was willing to wait. So the real test came when I actually went for a sail, and when I did that, I found that running the engine at 2100 in forward (about 6-6.5 knots) raised the temperature to 160°F and kept it there. The thermostat closes completely at 165°F, according to my service manual, so I think that temperature is good. I think that is also in line with other temperatures I've seen on this forum and elsewhere for Universal M25 and M25XP diesels. When I ran it at 2300 to 2400 this past summer, it went a little higher, perhaps to 170°F. With the old 2-inch heat exchanger, even before it leaked, I was only able to run the diesel at about 1800 rpms for long periods of time without the temperature raising about 180°F, so I'm pretty happy with the change. Generally, I think that 160°F to 180°F is the sweet spot, although I'm happy to be corrected if not.
Hope that helps!
Dave
My blog post regarding the topic: https://ericsonyachts.org/ie/ubs/ma...placement-exhaust-riser-rebuild-and-more.539/
Good luck.
Thanks @Kenneth K !
Thanks!
Dave
You should look at Mainesail's piece on the location of the alternator bracket, but I do not see a problem with your set up--though the view is not clear in the video. Seems like the previous owner did some work. on your engine: a KN filter, and a proper sea strainer--those were not standard from the factory, so maybe he already did this change. FWIW.Thanks @Kenneth K !
Thanks!
Dave
Thanks @Pete the Cat ,You should look at Mainesail's piece on the location of the alternator bracket, but I do not see a problem with your set up--though the view is not clear in the video. Seems like the previous owner did some work. on your engine: a KN filter, and a proper sea strainer--those were not standard from the factory, so maybe he already did this change. FWIW.
Seems I read that "contributing factors" to the old bracket's failure were higher output alternators, highly discharged batteries, and overtightened belts. Don't upgrade to a higher output alternator until you've replaced the bracket.Perhaps the thing that has saved me from failure is the fact the engine has relatively low hours (about 1,100)?
