atomic2797
Hi all,
I have an '88 38-200 (Gettin' Knotty) with a M40 motor with <2000 hours and the Hurth HBW-100 transmission.
I'm been having what seems like a common issue with my transmission; slippage in forward gear. It shifts between all the gears just fine and reverse works great. It sometimes engages forward after several attempts. It was not a fun experience coming into Avalon harbor the last time with a full anchorage, 15k winds and a forward gear that wouldn't engage.
I'm going to try some simple adjustments today with the cable, but from what I've read this is a common issue with these transmissions. So I'm already mentally planning for a full replacement.
My 2 questions are:
1) What is the best replacement transmission on the e38 w/ a M40?
By best, I mean a transmission that swaps in with little adjustment or modification to the vessel. Most importantly though is DEPENDABILITY. Is the ZF10 any better or just a new company with the same product? I also see that Dan Morehouse swapped in an upgraded ZF15 which he stated was a better fit than the ZF10? Would love to hear feedback on that as well.
I've been reading about the PRM 120 D2 which sounds like it is much more reliable. Does anyone have experience with this transmission? Any other brand that I should consider?
2) How difficult is the transmission replace & install on the 38-200? That entire engine compartment is pretty tight. I've very good with mechanical fixes, but i dont have the time to do an engine removal if that is what it requires. Would love to hear the process/see pics if anyone has done it before.
Thank you in advance!
-Andrew
My 2 questions are:
-Andrew
