What is the concessus on adding a spinnaker halyard crane to the mast head? My boat did not come with a spinnaker but I am planning to buy an A-symeterical this coming season. I'm guessing I may have to re-route the halyard through a halyard mast exit plate below the sheaves and up around the block which would be attached to the crane. Since I do not plan to use the spin pole topping lift I was thinking about turning that exit plate around and using what was the pole topping lift exit plates for my spin halyard. As a side note I also would like to get a whisker pole for this boat and I've not used one on a boat this large before. Does a whisker pole for a boat the size of an E34-2 need a topping lift?
For those of you with the later 80's boats what experiences do you have flying kites with out a crane? Any issues performing outside jibes and wrapping the halyard around the top of the forstay? Any signs of wear or chafe? Any damage to the mast head sheaves?
I do intend to change the sheaves from wire to rope and install new amsteel core halyards this spring as well.
-Jason
-Jason
