bulkhead replacement
hvantrigt
I have a erickson 29 and im trying to replace the main bulkhead do I need to jack up the cabin or will the compression post support its weight when the bulkhead is removed
Hans
tenders
Innocent Bystander
That's a deck-stepped mast, right? Is the mast up?
The compression post is more than adequate to support the mast in resting mode but you're still going to want to use a bottle jack to lift the deck up out of the way of the bulkhead. They're $20 or less at Harbor Freight. Remember to loosen the shrouds a lot before jacking.
