I have removed the lower portion of the triangle shaped teak veneer that is all the way forward in the v-berth in my 1988 32-200. Anchor locker is leaking and caused rot in this area. Planning to replace the veneer but have a question about the area below the anchor locker since most of the water goes down there as it leaks.
Does anyone know if the cavity below the anchor locker down to the bilge or hull connects with the rest of the bilge. I am now concerned that water that leaks through the actor locker is trapped down there. Thanks in advance for any insight!
