Needed to build a "platform" for the high water alarm float switch in my bilge, as the previous owner just had it hanging out on top of the centrifugal bilge pump, not even affixed to anything, which rendered it pretty useless. Bought a small sheet of HDPE (StarBoard), cut a few 2" x 5" strips to layer together, which I was then going to stick to the bilge floor, and affix the high water switch on top of the platform, so it would be higher than the pump float switch. I planned to use the mother of all adhesives - 3M 5200 - to stick everything together.
At this point, I'm guessing all you expert repairers and restorers know how that went. For those boat maintenance newbies like me, here's the takeaway - 5200 doesn't work with HDPE. I scuffed the HDPE board a lot, but still, the 5200 didn't want to stick. Not even a little. My fault for not checking beforehand, but I just assumed it would. Come to find out HDPE and 5200 are apparently mortal enemies.
So, back to the drawing board, I bought a roll of 3M VHB tape which was said to work with HDPE. Happy to report it does. Built the platform with layers of the tape, stuck it to the bilge floor, taped the float switch to the platform, and now have a (hopefully) reliable high water alarm. We keep calling it our "learning boat" for a reason.
