1987 Aluminum rub rail
RKlemm
I have rub rail from a 1987 32-3.
Cut into 8' sections. 31' is clean no bends, maybe 25' with some bends. I'll get that info if someone needs more than 31'. I can send everything if you want to try to take out the damaged area. Your call.
I'm currently replacing all of it with a more robust rubrail with insert.
Not sure the value other than it's hard to come by. $30.00 per 8' section plus shipping.
If the hull flange interferes, it can be ground down a bit as necessary.
You've probably seen this (the Taco product is now Special Order only):
RKlemm
Yes, I've seen that profile. I went with a semi rigid rail with Insert.
I sealed the face with 4200 and drove the screws in with butyl tape.
It's not original to the style but neither are my race sails and electronics.
Thank for the information
