CNG to Propane Conversion [Master Thread]
vanilladuck
E32-3 / San Francisco
Bryan,
Does your locker lid have a hole in it like this?
Even though a leak and overflow is unlikely, there is an opening portlight at the foot of the quarter berth which opens to the cockpit deck. I'm thinking about plugging those lid holes with something like this:
It should keep some of the rain out too. With turning off the valve and routine drain checks, I'll be able to smoke the occasional stogie with a little more peace of mind.
J
No, the aft lazarette lids on the 32-3 are solid with no perforation
Nice solution for covering the hole. Be sure to seal the holes and the circumference with Sikaflex 291 or similar to keep the salt and spray out
lightbulbjb
What did you all use to secure the supply hose on its way from the locker to the appliance? The current CNG installation my boat came with is.... Just a bunch of hose laying on the shelf in the lazarette...
I was thinking of using the zip ties with a hole to screw them to a surface, likely hanging. I do worry a bit about chafe on the hose tho.
Ref "sealing" the propane locker: I've been crawling around in the stern of my boat the past few days replacing scupper hoses. While under there I came upon the two Zurn/Qest fittings for the anchor locker drain. Both were barely hand tight, and the hose clamps rusted shut. The connection between the fittings the hose was so loose I was able to pull the hose off without freeing the hose clamps. Might be worth checking out....
They come in various sizes and I think I used the larger ones I've been meaning to crawl in there and take some pictures (I need to get in there for some other projects too), but I forget every time I'm down on the boat.
Bryan,
J
I have a locker with a hole in it like that on both of my boats. However, someone (factory? PO?) put round head bolts loosely in them-which I always took as a handle to snatch the lid open. But your idea would certainly work and be more elegant. I disagree with the idea of having the lid too tightly sealed. My thinking is that if you actually believe propane is heavier than air it needs to have air to replace the leaked propane or you might be making a bomb out of the locker from a spark from your grill or a smoker's careless ash. Also, there is H20 condensation from propane tanks that seems like a good idea to dissipate rather than bottle up and rust stuff. I would add that the drain is a maintenance item. They do fill up with stuff and flushing on some schedule seems like it should be on the check list. As I mentioned, I do not think it a good idea to leave the tank valve open and rely on the solenoid. I sort of consider the solenoid a safety back up in case I forget to close the tank valve. This also gives me a regular check with the pressure gauge of the integrity of the gas line to the stove. I like having a switch on the main panel for the stove--I realize it is redundant to the sniffer switch, but I like to leave the boat knowing all switches are "off" and the panel tells me that when I leave the boat. FWIW.
lightbulbjb
I ended up passing the supply hose thru some 1" pvc pipe that I secured to the liner with pieces copper hanger strap that I bent into little "d" shapes. I forgot to take pictures, and have a bit of work left to do to put in the straight thru. Will share when I get back to the boat next weekend.
Peaman's advice about drilling a hole thru a fitting to pull thru a messenger worked perfectly. Thank you!
Ended up drilling a hole in the top right corner of the panel behind the galley to fit the sniffer cable thru.. Do I need to add vapor-tight straight thrus to where the hose and the sniffer come into the galley, or is the sniffer hooked to the solenoid control good enough protection?
. . . Do I need to add vapor-tight straight thrus to where the hose and the sniffer come into the galley, or is the sniffer hooked to the solenoid control good enough protection?
I'm not planning on that. My thinking is that the gland is only necessary where there's potential of gas getting through. With a continuous hose it would either be at the stove or the regulator assembly.
lightbulbjb
Lol, good, cuz I glued the angled panel at the bottom down around the edges when I reseated it (after prying it up to fish the sniffer thru). The screws were kinda stripped, and I thought it might be smart to help seal those seams. I'm sure I could get it back off if I wanted, but really don't feel like scraping caulk and all that.
I am planning on making sure there are chafe prevention measures wherever I can reach.
I found these helpful:
captainic
Have '86 E35-3 with CNG system and want to convert to propane. I've heard the stove can be modified (re-jetted?). If so, where can parts be obtained? Then, put adapter on existing CNG hose and run extension to stern propane tank wells? Is solenoid shut-off required at tank?
I converted an old CNG stove (two burners plus oven made by GSI, Gas Systems Inc.) to propane, using LP gas orifices (jets) from 24/7 Parts Inc. It has been working well in my boat for years, but keep in mind this is not advisable, especially if there are no thermcouples at the burners to shutoff the gas in case the flame is blown out. The heat from burning LP is about 2.5 higher than from burning CNG, so the orifices need to be downsized accordingly; the flux ratio CNG/LP needs to be about 2.5, so if one knows the size of the CNG orifices, one can calculate the size of the LP orifices from [square radius of CHG orifice]/[square radius of LP orifice] = 2.5 ...and don't forget that radius = half the given size (diameter) of the orifice. In my case I downsized from 0.041" CNG orifices to #72 (0.025") LP orifices. Disclaimer: this is just FYI, not advisable, and the conversion here is not garanteed to be correct; try only at your own risk!
See also:
These are some other EYo posts which are related:
https://ericsonyachts.org/ie/threads/cng-locker-necessary-if-so-how-to-construct.2850/ (almost 20 years old, includes ABYC regs on CNG, advice to try to convert stove to LPG is probably not good now, not safe or to code unless there's a thermo shut off added too)
